Hier ein Link zur US Genesis Seite mit der Beschreibung des Modells 2024. Es gibt jetzt dann ein Wifi Hotspot. Batterie Größe etc. bleibt wohl gleich.
https://www.genesis.com/content/dam/genesis/us/com/pdf/2024/2024_GV60_Specs_Sheet_vfin.pdf
Hier eine kopierte Liste der Änderungen laut dem Mitglied:
- The brochure lists a Standard RWD option, with a 168 kW Rear Electric Motor (max 225 hp / 258 lb-ft), 19" wheels and the same 77.4 kWh battery. The range is listed as 294 miles, compared to 248 miles for the Advanced AWD and 235 miles for Performance AWD. The Standard RWD is not an option to "build" on the website yet, but I did find a bunch on The EV Finder by searching west coast zip codes.
- MSRP increased for both trims by $1260
- Virtual Gear Shift is available on the Performance
- Highway Driving Assist upgraded to HDA2 on all trims
- Wi-Fi hotspot is available on all trims
- 10 airbags instead of 8 airbags
- The Sao Paulo Lime green color has been retired (RIP to a very fun and unique color). In its place, Genesis appears to be offering a beautiful Barossa Burgundy color. This color is not yet an option on the build page and I couldn't find any scheduled for delivery, so we will have to wait and see if it becomes available in the future.
